BigT1960's avatar
BigT1960
Follower
Nov 06, 2021
Changing the carrier on an MR5200
Hi,I just purchased an MR5200 mobile router and I cant get it to change carrier networks from AT&T to T-Mobile. Any help would be appreciated
  • Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
    Thank you
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please advise what T-Mo plan you are using. Recently, we found out that some T-Mo promotion plans will not work with M5 since these plans usually tied to certain devices. Please contact T-Mo to change your plan. If you get the T-Mo SIM for their BYOD mobile hotspot plan, it will work with M5.
    t-mobile.com/cell-phone-plans/affordable-data-plans
    t-mobile.com/support/devices/not-sold-by-t-mobile/bring-your-own-device-byod-guide
    Thanks
    John
