JasonW72's avatar
JasonW72
Initiate
Jun 07, 2018
Changing the IP address
So is there a way to change the 192.168.1.1 default gateway IP address on this unit?
we want to use it as a failover for our current dodgy wireless network but we cannot change the IP address on it.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi JasonW72,
    Welcome to NETGEAR Community!
    As I understand, you want to change the default gateway IP address. Here's how:
    1. From a computer that is connected to your network, launch a web browser.
    2. Enter http://192.168.1.1.
    A login page displays.
    3. Enter the administrator login password.
    The password is case-sensitive.
    The dashboard displays.
    4. Select SETTINGS > Setup > Router Setup.
    The ROUTER SETUP page displays.
    Blanca
    Community Team
    • JasonW72's avatar
      JasonW72
      Initiate
      Thank you,
      the issue is that an error tells me to please use an IP address within DHCP range and wont allow me to change it out of 192.168.1 scope, even with DHCP turned off.
      • Blanca_O's avatar
        Blanca_O
        Hi JasonW72,
        Please provide a screenshot of the said error message.
        Blanca
        Community Team
