Prunella's avatar
Prunella
Circle with line going through
I have a circle with a line going through it could anyone give me a clue to what it means please
  • FURRYe38's avatar
    Not much to go off.
    Is there a screen capture of what your seeing?
    Is this in regards to a NG product? If so, what model # product do you have?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
    • Prunella's avatar
      Prunella
      Thanks for replying its a netgear MR21000 mobile router, there is a small circle with a diagonal line going through it as if it is a no entry 🚫 it's in grey though thanks
      • FURRYe38's avatar
        I would refer to the user manual for all information regarding this model router.
