directs
May 19, 2018Aspirant
CM500 download speed reduced.
My ISP is Wowway and I am using a CM500 router. Download router speeds were fine (100+mbps) for several months. All of a sudden speeds dropped to 20 mbps. Upload speeds are fine. Wowway says ther...
JasonN
May 21, 2018NETGEAR Employee Retired
Hi Directs,
Thank you for posting in the community. NETGEAR has already replaced your device and is still having the same issue. They also said that the firmware is provided by your ISP. Is there a reason why your ISP is not giving you the firmware? If you refer to the support page of the CM500, under firmware. It says that the firmware is pushed out through your ISP and not from NETGEAR.
Please let me know. :]
- Jason N
directs
May 21, 2018Aspirant
Hi Jason! I requested this from my ISP, but they are reluctant to update the firmware. I have read on the internet that this has been a problem with Wowway. I am not convinced that it will solve my issue as I was running at top speed for almost 2 months and all of a sudden it bottoms out. Their suggestion.....try an Arris. Crazy when the Netgear CM500 is on their approved list.
