gyruss's avatar
gyruss
Command or script to reboot Nighthawk M1?
Is there a command or script to reboot the Nighthawk M1 without entering the gui?
  • Perhaps you could modify that script that "turns off data and turns data back on" to do a reboot instead.  Of course that script is used to fix certain problems without having to wait for a reboot, so, depending on what you are trying to accomplish, you may be trying to fit a square peg into a round hole instead of using the square hole right next to it.
    • gyruss's avatar
      gyruss
      I tried that script but for some reason didn't detected that my connection was down. Perhaps because only the ports 80 and 443 are the only ones blocked. Also I have tried logging to the router and turning off and on the data but that didn't work either. The reboot did the job.
      • icaruspony's avatar
        icaruspony
        Luminary
        Ports 80 and 443... sounds like AT&T.  Connected Car Plan?
        You can easily modify the script to detect a web connection:
        import httplib
        conn = httplib.HTTPConnection("www.netgear.com")
        conn.request("HEAD", "/")
        r1 = conn.getresponse() print r1.status, r1.reason
        If it is reachable, it returns:
        200 OK
        You could also modify the on/off data to click the reboot button in the router. I've also heard changing bands is like a reboot when it comes to this problem.
