Quigly
Mar 22, 2018Follower
Compatibility with Cable systems
I just purchased a new CM700 cable modem. I am thinking about switching my internet provider. I need to know if the CM700 cable modem is compatible with the Century Link fiber optic system. Thanks...
JasonN
Mar 28, 2018NETGEAR Employee Retired
Hi Quigly,
It should be compatible but you would have to confirm with your ISP
Below are the links to the Specs Data Sheet & User Manual for the CM700:
Data Sheet:
https://www.netgear.com/images/datasheet/cable/CM700.pdf
User Manual:
http://www.downloads.netgear.com/files/GDC/CM700/CM700_All_MSOs_UM_EN.pdf
Please let me know if you need anything else. :]
- Jason N
