Binway's avatar
Binway
Follower
Mar 05, 2016
connect to wifi router without internet wifi dongle
Hi All,
I was attepmting to add my MBR624GU wifi router to a network via the Bridge.  I was attempting to follow the instructions for bridging and got a DNS error and couldn't get back into the configuration tabs.  So I followed the rest process which seems to have worked.  Alrthough for me to get into the configuration page it wants me to go through the setup wizard.  Is there a way to get to login without going via the setup wizard as it wants me to connect to the internet via the wifi modem that ai no longer have.  I have tried 192.168.0.1/login and 192.168.1.1/login but they alkl take me to the setup wizard first.
Any help appreciated
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Binway
    If it does not give you the option to skip the setup wizard at the start then no there is no back way in to skip that process.
    DarrenM
