Romseycanuck
Jan 10, 2019Aspirant
connected no internet when AC800S cradled in DC112A
I have been using an Optus, AC800S, to provide internet to our property. Because of the distance between house and a shed I attached an usb wifi adapter to the PC in the shed. This worked great.
Blanca_O
Jan 13, 2019NETGEAR Employee Retired
Hi Romseycanuck
Welcome to NETGEAR Community!
Our support team is looking into this issue and would like to work with you. I will PM you requesting for more information.
Blanca
Community Team
- KenrokoVAFeb 16, 2019AspirantBlanca
I am having the same issue. My DC112A was working perfectly for months but yesterday I accidentally checked on item in the configuration (Access point I believe) that caused it to reboot. I keep trying the reset button to factory defaults but when cradled by Aircard Hotspot the Internet light is still amber. I cannot Access the DC112A at all .. either wireless or connected with Ethernet cable.
Your assistance would be greatly appreciated.
Regards
Ken- KenrokoVAFeb 16, 2019AspirantI held the reset button for 60 seconds and the default configuration was reinstated and internet connection with Aircard resumed (amber turned to Green). Read this tip by looking at other posts.
