ben1989
Jan 25, 2016Follower
connecting aircard 810s to aircard cradle
When i plug my aircard 810s into the aircard cradle it says "wifi hotspot inactive while using wifi dock" as soon as i take it out of the dock it works fine. Any idea how to get it working while on th...
DarrenM
Feb 08, 2016Sr. NETGEAR Moderator
Hello Tony-M
I would first tryt to factory reset the DC112A and then go threw the setup again to see if it will merge with the aircard. Also check the internet setup page in the settings it has options for Internet source make sure the option to use the mobile broadband is selected.
DarrenM
SteveG49
Apr 19, 2016Aspirant
I have exactly this issue, even just from the base config, upgraded the firmware no fix. When I plug in the 810S it does not recognise it's docked and what is interesting is the external aerial I have via the TS9 seems to still improve the signal, but overall the performance of the 810S is terrible when docked, unplug and it works,
