ben1989
Jan 25, 2016Follower
connecting aircard 810s to aircard cradle
When i plug my aircard 810s into the aircard cradle it says "wifi hotspot inactive while using wifi dock" as soon as i take it out of the dock it works fine. Any idea how to get it working while on th...
SteveG49
Apr 19, 2016Aspirant
I have exactly this issue, even just from the base config, upgraded the firmware no fix. When I plug in the 810S it does not recognise it's docked and what is interesting is the external aerial I have via the TS9 seems to still improve the signal, but overall the performance of the 810S is terrible when docked, unplug and it works,
mallinss
Jun 12, 2016Aspirant
I have the same issue, purchased both the DC112A and the 810S device, have it connected to an extremely high gain external antenna... with the 810S on its own (no cradle), I can consistantly download in excess of 100Mbps and Upload of around 25 ~ 35 Mbps, pretty awesome... but when I connect it to the cradle and then hook up the external antennas to the cradle ports, the perfermance degrades by more than 80%..quite poor... I have stopped using the DC112A Cradle.... FYI, on the Netgrear Site in Australia, the 810S is supported on the DC112A cradle...
Steve
