ben1989
Jan 25, 2016Follower
connecting aircard 810s to aircard cradle
When i plug my aircard 810s into the aircard cradle it says "wifi hotspot inactive while using wifi dock" as soon as i take it out of the dock it works fine. Any idea how to get it working while on th...
ArodiD
Mar 22, 2017NETGEAR Expert
Hi ben1989,
When you dock your AC810S into the Smart Cradle it will disable the WiFi on the AC810S automatically. This is normal operation. The Smart Cradle is a router and if you have a look at the label underneath the Smart Cradle you will notice there is an SSID and Passphrase printed. Use this to connect to the Smart Cradle over WiFi whilst the AC810S is docked and when you undock you will just need to manually switch back to the AC810S SSID.
Kind Regards,
Arodi
