HardrockF350
Sep 05, 2018Aspirant
connecting the M1100 to R7800
after connecting the M1100 with an ethernet cable to the R7800 nighthawk router, the R7800 did not have any internet service. the only way it would work is to turn on IP passthrough in the m1100, co...
- Sep 07, 2018
Hello
Well you are using 2 routers, it's unusual.
Keep your MR1100 in router mode, but your R7800 needs to be set to "Acces Point mode".
See manual page 73:
http://www.downloads.netgear.com/files/GDC/R7800/R7800_UM_EN.pdf
Tellurium
Sep 07, 2018Apprentice
Hello
See manual page 73:
HardrockF350
Sep 07, 2018Aspirant
i did not know i could change the R7800 to be an access point, thanks for the document. the m1100 does not send out a strong signal outside my home, that is where the R7800 works better. first of all i had the R7800 connected to the LB1120 modem, then i heard about the M1100 has better service, and it does, also i can disconnect it from the R7800 for traveling. thanks for your help.
