Lostinthecorn
Jul 14, 2016Follower
Connecting Unite explore mobile hot spot to nighthawk router and adding a wifi range extender.
Moved far enough out that the fiber doesnt reach. Using a Unite Explore mobile wifi hotspot the signal comes in great with good speed (72-144 mbps vs 20 down 8 up on the phone copper line).
Can I use a netgear wifi range extender to reach the far corners of the property and/or can I use my nighthawk router to pick up the wifi signal and transmit through the hard wires going to each room? Or something else. Distance and strenght are the issues.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Lostinthecorn
Does the mobile hotspot have a Ethernet connection in order to connect it to the Nighthawk router? if so you could hook it up to the router. And you should be able to use a extender to reach distant spots in your home just fine.
DarrenM
