RichardVDV
Sep 05, 2022Follower
Connection Issue
Hi Guys. New to this. I have a NightHawk 5100 attached to Telstra who is our Telco. The Nighthawk shows it is connected to 4G with strong signal but I get the message - No Internet Connection. Is there possibly a fault with the unit or is there a fix please.
Thanks for any help - Richard
RichardVDV wrote:
Hi Guys. New to this. I have a NightHawk 5100...
If you are looking for similar messages, that's probably the MR5100.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. - Blanca_ONETGEAR Employee Retired
Hi RichardVDV,
If you are connected to the mobile router but cannot connect to the Internet, try the following suggestions:
• Check the display status on the LCD.
• Make sure that network coverage is available in your area.
• Make sure that your SIM card is active and enabled with data services.
• Confirm that your account is activated and that no other Internet connections are active.
• Switch your mobile router off and on and restart your computer or WiFi device.Regards,
Blanca
Community Team
