YouUseYourName
May 29, 2017Follower
DC112A AirCard Smart Cradle - Devices have issues re-connecting to WiFi
I bought a Telstra WiFi 4GX Advanced III with an AirCard Smart Cradle back in January. I have had no issues connecting to the 4GX Advanced III's WiFi itself, at all. I can disconnect it from the ...
DeyoSwed
Oct 29, 2017Tutor
Yeah i got the same problem it is really innoying specially because this is bye far my most expensive router setup i have had til now!
Wombo24
Nov 03, 2017Guide
DeyoSwed wrote:Yeah i got the same problem it is really innoying specially because this is bye far my most expensive router setup i have had til now!
I have the same issue here on a new DC112A, it will not issue an IP to one W7 laptop and the attampted wifi connection remains at "unidentified newtwork" & "No internet access". Factory resets & reboots have no effect.
The laptop has always been fine and otherwise continues to connect directly via wifi to the two AC810S and a AC790s along with a number of other devices with no problems whatsoever.
Direct connect cable works OK, it's clearly a wifi related problem.
Very annoying
- JamesGLNov 09, 2017NETGEAR Employee Retired
Hi Wombo24,
Is it the only device that will not grab an IP from the cradle?
What are the devices that works fine with the cradle?
Which Aircard unit connected to the cradle?
- Wombo24Nov 09, 2017Guide
Yes its one out of 4 laptops that isn't being issued with an IP. The other 3 other laptops (mix of W7 & W10) work OK as do a couple of Android phones.
I've tried 4 different Aircards in the cradle, 2 x AC810s & 2 x 790s. Same issue.
However the laptop having the issue will establish a wifi connection fine to everything else - all of the above aircards individually, as it will and has reliably for a long time to, numerous other Billion, ZTE, Netcomm & Netgear & Sierra vintage aircards we have here - a total of around 15 devices that continue to work fine with it. It's only the DC112A that refuses to play. It the attached devices screen the DC112A regognises & lists the laptop MAC address but all the other fields have "-----" same as posts above.
If I connect it via ethernet to the DC112A it works OK.
- DeyoSwedNov 13, 2017Tutor
For us we have 4 devices always connected a samsung s5, s6 and 2 brand new gaming laptops.
I run default config on cradle.
I can get all devices to connect to the 5ghz wifi and internet will work fine, but after a while connection stalls out for the mobil phones, the laptop however will still be connected to wifi and the internet.
When loggin to the cradle setup the phones show up in connected device list their just not reciving wifi on their end.
The fix has been for me to remove aircard 810s from cradle and plugg it back in or restart device, still very innoying.
