Cuffuffles
Jun 30, 2016Tutor
DC112A Firmware problems
I am using the DC112A with an 810S for home internet over 4G. When I first got the device (firmware 1.0.0.24) there was a issue where, when streaming (to twitch/hitbox etc) my ping would spike to aro...
Cuffuffles
Sep 11, 2016Tutor
DarrenM Just wondering if there has been any update on this?
Did my attached files point towards a specific problem? Possibly something that could be fixed without a firmware upgrade?
voodoo69
Oct 16, 2016Aspirant
Netgear smart cradle dc112a -1Z1MES firmware Firmware Version 1.0.0.12
I try to update my smart cradle from Netgar site firmware version 1.0.0.12 is unable to install. Heres what i get when i try to install the firmware "the firmware file is oncorrect! Please get the firmware file again and make sure it is the correct firmware for this product"
https://www.netgear.com/support/product/DC112A%20(Zain).aspx#Firmware%20Version%201.0.0.12
Right now my Firmware Version 1.0.0.4 (Initial Release).
Can you help me ?
I would like to this 1.0.012 firmare beacause :
Bug Fixes:
- Fixed the issue where the Cradle UI does not show 4G+ RAT icon, when the MHS is connected to two or more LTE CA Bands support.
- DarrenMOct 19, 2016Sr. NETGEAR Moderator
Hello voodoo69
Try to load the firmware using TFTP see if that works.
DarrenM
- voodoo666Nov 11, 2016Aspirant
Don't work.
DC112A-V1.0.0.12_1.0.60 - DC112A-V1.0.0.12_1.0.60OOREDOO.chk work in station DC112A-1Z1MES(Zain)?
Auto update not detected this firmware only Firmware Version V1.0.0.4_1.0.60.
Why this update don't work in my DC112A Zain ?
http://kb.netgear.com/app/answers/detail/a_id/30803/~/dc112a-(zain)-firmware-version-1.0.0.12 .
Only
Previous Versions
Firmware Version 1.0.0.4 (Initial Release) work ;/.- voodoo69Nov 15, 2016Aspirant
Firmware don't work in Zain Cradle.Can Netgear fix this firmare?
http://kb.netgear.com/app/answers/detail/a_id/30803.
Netgear smart cradle dc112a - model: 1Z1MES (Zain). Don't work. Cradle is Zain,but autoupdate (search update) Cradle don't see this update.Firmware don't updare needen't.Now my Cradle Zain firmware is Version 1.0.0.4 initial realase. Can I update this cradle to DC112A-V1.0.0.12_1.0.60.I have Zain Cradle ;/
DC112A-V1.0.0.12_1.0.60OOREDOO.chk . What is OOREDOO?Why this update don't work all Zain Cradle ?
Please help!!!
I try this DC112A-V1.0.0.12_1.0.60OOREDOO.chk but error firmware ;/
