Cuffuffles
Jun 30, 2016Tutor
DC112A Firmware problems
I am using the DC112A with an 810S for home internet over 4G. When I first got the device (firmware 1.0.0.24) there was a issue where, when streaming (to twitch/hitbox etc) my ping would spike to aro...
JakeMuSS
Nov 15, 2016Aspirant
Netgear can we please get a way to downgrade this device. 1.0.0.30 firmware has stuffed 2 of the cradles and need them working?
Cheers,
Jake
DarrenM
Nov 16, 2016Sr. NETGEAR Moderator
Hello JakeMuSS
Have you tried to downgrade via the firmware on the support page?
https://www.netgear.com/support/product/DC112A.aspx?cid=wmt_netgear_organic#download
Voodoo69
I am looking into the issue you are having with the Zain Dc112A
DarrenM
- JakeMuSSNov 16, 2016Aspirant
Hi DarrenM,
Yeah the problem is you can downgrade, it does not have the ok button when you try it.
Cheers,
jake
