Cuffuffles
Jun 30, 2016Tutor
DC112A Firmware problems
I am using the DC112A with an 810S for home internet over 4G. When I first got the device (firmware 1.0.0.24) there was a issue where, when streaming (to twitch/hitbox etc) my ping would spike to aro...
DarrenM
Nov 16, 2016Sr. NETGEAR Moderator
Hello JakeMuSS
Have you tried to downgrade via the firmware on the support page?
https://www.netgear.com/support/product/DC112A.aspx?cid=wmt_netgear_organic#download
Voodoo69
I am looking into the issue you are having with the Zain Dc112A
DarrenM
JakeMuSS
Nov 16, 2016Aspirant
Hi DarrenM,
Yeah the problem is you can downgrade, it does not have the ok button when you try it.
Cheers,
jake
- DarrenMNov 17, 2016Sr. NETGEAR Moderator
Hello JakeMuSS
I inquired about this and what I have been told is downgrading the firmware on the Dc112A is not supported.
DarrenM
- JakeMuSSNov 17, 2016Aspirant
Hey DarrenM,
Hmm so upgrade the firmware and stuffs the cradle up then can't downgrade... that is nuts!
Cheers,
Jake
