Cuffuffles
Jun 30, 2016Tutor
DC112A Firmware problems
I am using the DC112A with an 810S for home internet over 4G. When I first got the device (firmware 1.0.0.24) there was a issue where, when streaming (to twitch/hitbox etc) my ping would spike to aro...
Saltwaterjunkie
May 23, 2017Aspirant
I have this exact problem too. Has this been solved for anybody yet.
CarlChapman
Has not been fixed yet... I checked my system the other day and the firmware is still on version V1.0.0.30_1.0.60.... its been over 6 months for me now.
- Shane822Nov 17, 2017Initiate
I just bought a DC112A router second hand and it has the following firmware on it:
Current Firmware Version 1.0.0.24 New Firmware Version 1.0.0.32_1.0.60 So it seems like there is a new version to the 1.0.0.30 that you guys are having problems with above... However, I can't install this firmware as says "Firmware invalid" after the download... Anyone able to help with this?
- ABursellNov 18, 2017Aspirant
I have 3 DC112A's and all are on version 30 and all see version 32, but they report the same invalid error when trying to upgrade.
- BobHxNov 18, 2017Aspirant
I can also confirm that trying to update from Current V1.0.0.30_1.0.60 to New Firmware Version 1.0.0.32_1.0.0.32_1.0.60 gives me the 'Firmware is invalid' message.
Device settings are as per factory, but using WAN port for internet.
The download centre at https://www.netgear.com/support/download/?cid=wmt_netgear_organic has this message 'Firmware/Software not available for this model.'
Any ideas?
