Amermadi's avatar
Amermadi
DC112A internet connection without ducting AirCard 810s mobile hotspot
Dear all,
If i keep mobile hotspot ducted on the cradle it will keep on charging the battery! And maybe this will effect the performance of battery in the future! (because when it's 100% charged message will apear to remove mobile hotspot).
Once removed, Aircard smart cradle Dc112a won't provide internet anymore!
Is there any solution?
Thanks,
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Amermadi
    are you saying once the aircard hits 100% battery on the cradle the Dc112a stops broadcasting the wifi?
    DarrenM
  • Hello Darren,
    No, it still can broadcast the wifi.
    What i mean is:
    Can remove aircard from cradle and keep using cradle as wifi booster without losing internet? Because aircard coverage is not enough!
    • DarrenM's avatar
      DarrenM
      Hello amermadi
      no the aircard would need to be docked.
      DarrenM
