Wombo24
Apr 13, 2018Guide
DC112A setting attached device names doesn't stick
Meaningful device names can be set for each device under Access Control by editing & applying for each device entry manually. However after logging out & in again later the previously set names i...
JasonN
Apr 24, 2018NETGEAR Employee Retired
Hi Wombo24,
Have you tried doing a factory reset on the device? If not, please proceed and update me with the outcome. :]
- Jason N
