lestrange78
Apr 11, 2018Aspirant
DC112A Slow internet speed using cradle
Hi there- my first post.
I've just purchased and connected an Aircard 800S (Optus carrier) and a DC112A cradle.
The internet speed is averages 24mbps when using the Aircard without the cradle
The internet speed using the Aircard docked in the cradle is 1-2mbps at best. Both devices are in the same location (on the windowsill).
Our closest cell tower is 2.5km away offering all Optus 3 & 4G frequencies.
Any advice or recomendations?
Thanks.
- JasonNNETGEAR Employee Retired
Hi lestrange78,
Thank you for your post. I wanted to check if your cradle is up-to-date with the most current firmware? If so, have you done a factory reset on it?
Also, if your AC800s is at the current firmware as well.
Please let me know. :]
- Jason N
- lestrange78AspirantHi Jason,
Yes- both devices have had firmware updated and a factory reset was done on the cradle.
Any other suggestions?
Thanks.- LlamaLarryLuminary
Different model (AC815S) and location (US), but this is not what I am seeing in my DC112A. I do use external antennas on mine however, but get 50Mbps/10Mbps via Ethernet when docked.
