EricT01
Nov 04, 2016Aspirant
Dc112a Smart Cradle
Hi When my devices are away from the Smart Cradle for a long period of time, they have trouble connecting. Even though they have been connected before. This is through the wifi. So password has b...
EricT01
Nov 12, 2016Aspirant
Hello Darren
Sorry for the slow reply. The firmware is up to date. I've only just bought the Cradle. It's only happening with my iPhone 7 and iPad Air 2. Both devices are running the lates iOS. Even when I move out of wifi range and return to it, it doesn't connect automatically. I've even tried forgetting the network, and then reconnecting. The only thing that seems to work is to reboot the air Cradle. As I live in a rural area, I've resorted to turning off the security.
voodoo69
Nov 15, 2016Aspirant
Firmware don't work in Zain Cradle.Can Netgear fix this firmare?
http://kb.netgear.com/app/answers/detail/a_id/30803.
Netgear smart cradle dc112a - model: 1Z1MES (Zain). Don't work. Cradle is Zain,but autoupdate (search update) Cradle don't see this update.Firmware don't updare needen't.Now my Cradle Zain firmware is Version 1.0.0.4 initial realase. Can I update this cradle to DC112A-V1.0.0.12_1.0.60.I have Zain Cradle ;/
DC112A-V1.0.0.12_1.0.60OOREDOO.chk . What is OOREDOO?Why this update don't work all Zain Cradle ?
Please help!!!
I try this DC112A-V1.0.0.12_1.0.60OOREDOO.chk but error firmware ;/
- DarrenMNov 16, 2016Sr. NETGEAR Moderator
Hello EricT01
It must be something related to the wifi in the IOS devices if they are the only one having the issue I will try to look up if some setting needs changed to fix this.
Voodoo69
I am looking into the issue you are having with the Zain Dc112a
DarrenM
- racersimageApr 29, 2017Guide
I am having this problem as well with a new DC112A-100NAS. Mine and my wifes iPhones can initially connect but when we leave for the day and come back, they will not automatically reconnect. When I try to connect to either the 2GHz or 5GHz network, I am prompted for the security password again and again.
