jpsolarzap
Jul 17, 2018Follower
Deeper into APN settings on AT&T Unite series Hotspots (781S specifically)
The APN settings through the manager for my device (Aircard 781s - AT&T Unite Pro) are lacking and (likely) causing inability to use other networks. I have to set-up the hotspot to have the following settings, is it possible through other utilities/software?
APN: RESELLER
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
Authentication Type: None
APN type: default,mms,supl
APN protocol: IPv4
Bearer: Unspecified
1 Reply
- EianzAspirant
These settings are not working fro me seems like they updated their settings try these at&t apn settings instead
