Katemb
Apr 13, 2018Follower
Detecting service message on Nighthawk MR1100
The router constantly shows a message saying "detecting service". I can connect devices to it but not getting onto internet or if i do its very slow and usually times out. Took to telstra shop, first time they said it was a faulty sim card so changed that, no difference, went back and they said, "i can connect to it so it seems to be working fine". The bar on the right hand side that shows signal strength has been blank since the detecting service message appeared. All updates done, factory reset done. Does anyone have any ideas to help me get reception back please
Hi All,
We have released a new firmware today to address the broken data usage issue. This firmware also enables Arlo base station support and gives user the option to disable the Ethernet standby.
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
Kind Regards,
ArodiD
- hippolyteApprentice
Hi Katemb,
Here is a link that includes the same issue and some progress towards a solution.
Anyone-know-what-the-latest-firmware-for-the-M1100-fixs?
hyppolyte
- ArodiDNETGEAR Expert
Hi All,
Kind Regards,
ArodiD
