DariusG_TMUS_SE's avatar
Dec 04, 2019
Disable Master Reset
Is it possible to restrict the ability to perform a master reset via the hardware keys or pin hole, or from the admin menu?
  • Hi DariusG_TMUS_SE
    Welcome to NETGEAR Community!
    There is no option to disable the ability to factory reset the device via hard reset or soft reset.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi DariusG_TMUS_SE
    Blanca
    Community Team
