Helg1
Jul 03, 2015Follower
Do AirCard 785 support external WiFi antennas?
This review says it does. But i don't find any information about it elsewher:
Is it realy true that you can connect 2 WiFi-antennas to the TS9-connectors on the Aircard 785? Or are they only for getting better cellular signal?
(I know you can get a craddle, DC112A, to increase the WiFi-signal)
"Netgear also has made two points to fit external antennas should you need to boost the Wi-Fi range and speed (not to be confused with your cellular signal)."
http://www.trustedreviews.com/netgear-aircard-785-mobile-hotspot-review
1 Reply
- FairytailVirtuosoCheck these links.
http://kb.netgear.com/app/answers/detail/a_id/23901
http://kb.netgear.com/app/answers/detail/a_id/23385/~/how-is-the-external-antenna-connected-on-the-aircard%C2%AE-76xs-mobile-hotspot%3F
The Antenna is to boost your connection from the ISP and not for WiFi connection.
