N4KHQ
Feb 05, 2020Aspirant
Does Bridge or IP passthrough work with MR1100 or LB1120 when using AT&T
I have been reading the posts about bridge mode for several days and can't find the answer to my question. Does either the MR1100 or LB1120 work in bridge mode when AT&T is the carrier? Some say you ...
N4KHQ
May 28, 2020Aspirant
It works on the Nighthawk fine, problem is AT&T won't give the router a public IP number the router can use. It looks like AT&T is using class A IP numbers for the connection. I put my linksys Wifi router in Bridge Mode to solve the double NAT. They say there is a 20 or 22 IP limit but it has never been a problem for me. However, Double NATing is not the problem it used to be, you may find it is not a problem, either net connections works in bridge or regular mode. I think most modern routers must be doing some correction for double NATing these days. Maybe someone can tell us if the do.
Just read the previous reply and I think I understand. AT&T is sending NAT IP address from their site as opposed to the MR1100 giving local IP address. Is this correct.
LlamaLarry
May 28, 2020Luminary
I think that is correct. whatismyip reports a normal public IP (107.77.x.x), but the IP being reported to my router from my bridged LB1120/LB2120 is 10.x.x.x network (NAT 1), then my router hands out 192.168.1.x (NAT 2). I've never tried trying to set my router IP address and range to something in the network coming from the modem. I imagine it changes often which might be an issue.
I am definitely not a mobile metworking guy, just some dude trying to make it work in a rural area with no wired broadband.
