mr6150user
Jan 09, 2023Aspirant
Does MR6150 support NR band n78?
From Technical Support Manual, I can find that the MR6150 supports 5G NR band n77, but not n78.
As far as I know, the bandwidth of n77 (3300-4200MHz) includes the bandwidth of n78(3300-3800MHz), so n78 is also supported.
Does MR 6150 support NR band n78?
- JohnPengNETGEAR Expert
n78 is not supported on MR6150. But it may be supported by future FW upgrade.
Thanks
John
- mr6150userAspirant
Thank you for replying.
Then, Which frequency band range can be used from the n77 band (3300MHz - 4200MHz) in MR6150?
Another question is, can I change the center frequency of the MR6150?
- mistacoryAspirant
Is there any way we can pass this feature request up to those involved with updating and deploying firmware? I spent way too much money for a product a feel is limited when put to use.
