zombiedad's avatar
zombiedad
Follower
May 09, 2020
Double Nat on Xbox One (M1100 AT&T)
Hi everyone, names Zombiedad. I am a OTR Truck Driver and im having a issue with the M1 router and my xbox one. Being away from my family is tough even with whats going on right now in this country. but my issue is when im on my 10 hr break or my 34 hr break, i try to spend time with my family via xbox and play the games we like. im getting a Double NAT on my console. i have unlimited on it. which i know the speed shouldnt affect it but i need help on how to fix it. Hulu and netflix, amazon prime all work great, but the double nat is restricting me on connecting to them while on the road. im using the Netgear Nighthawk M1 with AT&T Business with unlimited. Im getting 4 to 5 bars on the device. Please help. thank you
1 Reply
  • Thanks for driving!
    I have never gotten an AT&T mobile hotspot to give me anything besides Double NAT.  :( I think all AT&T mobility IPs are behind Carrier Grade NAT (https://en.wikipedia.org/wiki/Carrier-grade_NAT) right from the start so adding our routers to the mix doubles it up.  Have you tried the normal things, put a static IP on your Xbox and then put that IP in the DMZ?  Or tried putting the router in Bridge mode and connecting it directly (and only) to the Xbox?
