Sawman27's avatar
Sawman27
Double NAT on xbox
Trying to play Xbox live and it’s saying I have a double NAT and a strict NAT. I only have the nighthawk hot spot. No router. I just need some guidance! Like Ethernet to the hotspot?? Orrr??? Anything helps!!
  • schumaku's avatar
    schumaku
    Not uncommon providers are using NAT, Carrier Grade NAT (CGN), or abusing RFC1918 addresses with CGN for assigning the "pubic" IP address to your mobile/MR1100.
    • Sawman27's avatar
      Sawman27
      So basically I won’t be able to play video games online?? That’s all I want.
      • schumaku's avatar
        schumaku
        Understood, but nothing the community here can change or enhance on your behalf. Start with challenging your mobile data provider with the keywords from above....
  • When doubling up on devices performing NAT, Xbox One can display the "Double NAT detected" error in the console's network settings. This is often caused by multiple routers of gateways between your Xbox and the internet, preventing it from establishing a steady connection for gaming upsers portal
