Speedsk8
Dec 28, 2019Tutor
Double NAT
Trying to grt rid of Double NAT on son's Xbox Have a Nighthawk LTE AT&T Modem thta directly feeds a unmanged switch. I have set the XBox to a static IP outside my DHCP pool, Set up the port forwarding in the router/modem for all of XBoxes listed ports including the alternate. I have tryed both wired and wireless conections. Still get the double NAT. Getting anoyed as I am ussally the one fixing IT issues for others.
This has been found to be a NAT issue from my provider and on that side I have no control so it will just be what it is till the new fiber makes it to my area.
- JohnPengNETGEAR Expert
Could you please try to enable IP passthrough on MR1100 and see whether it will help to resolve your issue?
Thanks
- Speedsk8Tutor
It does not that was one of the first things I did. I have found that my NAT issue is from the providerside and that I have no control over so it will just have to wait till I can get on the new fiber they are running .
- Speedsk8Tutor
