BAPreschool
Apr 26, 2021Initiate
EE Nighthawk M1 Gigabit LTE Mobile Router(MR1100EE)
Hi,
I have been using this router for almost two years with no issues. Suddenly it is displaying the message 'Your data connection is disconnected'. I have tried resetting the router, removing the SIM etc but nothing makes any difference. Is it a problem with the router or the data provider (EE)?
Many Thanks
did you check with the cellular provider?
- BAPreschoolInitiate
Immediately after posting this, haha! All sorted, thanks.
