rizkikhrais's avatar
rizkikhrais
Follower
Jul 13, 2026
error 1028
I keep getting error 1028 while my laptop is connected by WiFi to the Nighthawk MR6150-100NAS. When I look it up, it says Error 1028. All my other devices are working, but not the laptop. I checked for updates, but it says my device is up to date. Is there a solution for this? I use my laptop for work, and being constantly interrupted is very annoying.
  • Since the other devices are working normally, I'd first focus on the laptop rather than the MR6150. Try forgetting the Nighthawk Wi-Fi network on the laptop, rebooting both the laptop and hotspot, then reconnecting. If possible, test the laptop on another Wi-Fi network as well; that can help determine whether the problem is specific to the MR6150 connection or the laptop's Wi-Fi configuration.
  • schumaku's avatar
    schumaku
    Interresting only one connected device (computer) is affected. Using that one for some video streaming, remote desktop access, ... things causing a lot of traffic?
    1028 is PS_NET_DOWN_REASON_EMM_DETACHED
    JohnPeng​ please.
    He is very likely ask you to get som model.json data from your router, like ...
    • Logon to the webui (http://192.168.1.1 ) as an administrator
    • Navigate to URL http://192.168.1.1/model.json via the same browser window
    • Capture the results (by selecting all + copy) and send it back
    ...and submit the content of the model.json data to JohnPeng​ by PM.
