Jindarra
Feb 22, 2025Aspirant
Error 1056
- MR6110 connected to Telstra data plan in Australia showing data connection unavailable
- Then asks for APN to be Confirmed in SETTINGS> MOBILE > APN. But then wont show SAVE button to Confirm and shows ERROR 1056
- Junaid678Aspirant
Helpful!
- jmantInitiate
Hi Junaid678 have you found a solution to the Error 1056?
- JindarraAspirant
Hi rcpax
I followed that post on January 19, but have had no response. I thought the email may not be current, so I posted on here. The data from model.json I saved is attached
Is there a generic email at Netgear I could send the information to?
Thanks
- jmantInitiate
Has this been resolved I have the same problem with my Nighthawk M6 in Australia.
Error
Mobile Broadband Disconnected
Error 1056
This occurred when I removed the data sim which was on a plan with Telstra and swapped it with a prepaid data sim from the same company (Telstra).
Netgear Nighthawk M6 is currently useless to me now and its only 1 year old!
