JoshuaB123's avatar
JoshuaB123
Follower
Jul 06, 2019
External Antennas for Netgear LB1120
Hey guys, first time posting here.
So I live in The Bahamas, and we're trying to fix our LTE situation and as far as I'm aware, this LTE Modem does support GSM Carriers, such as we have here, and currently our LTE modem that we have, which I won't name, is really struggling and we're going to upgrade our entire system starting with the modem. The problem is, where the server room is located in the house, its pretty much in a concrete box with a door which really hurts our current LTE modem as the signal can't pierce through so many 8" concrete walls and we're looking to incorporate 1 or 2 Omni-directional antennas on the side of the house parrallel with the cell tower (its only about 1,500ft away). So my question is, are there any suggestions for compatiable antennas that will work with this LTE Modem? And do I need to buy 2 antennas or will one work as I notice there is a "Main" and "Div" TS-9 Female connectors on the backside of the modem. I'm currently looking at this antenna (https://www.amazon.com/Proxicast-Omni-Directional-Outdoor-Fiberglass-Antenna/dp/B074YWTCB1/ref=sr_1_3?keywords=proxicast+antenna&qid=1562374264&s=gateway&sr=8-3) and I'm going to use a 50ft N-male to SMA-Male coax cable w/ a TS9 Adapter. Will this setup work, or should I use two 9/10db Directional Antennas instead? Such as this (https://www.amazon.com/TECHTOO-Directional-Cellphone-Amplifier-Signalbooster/dp/B00RYVLR4G/ref=sr_1_8?keywords=1900mhz+4g+lte+antenna&qid=1562375206&s=wireless&sr=1-8)
Also, our service provider in the Bahamas is BTC, or BATELCO, which is supported by the modem according too Netgear's compatiablity list of carriers. Thanks guys.
1 Reply
