rightleft2's avatar
rightleft2
Firmware update failing for LM1200
I get the message Firmware Update Failed, Invalid update file. The package is not supported when I use the firmware provided here
These are my hardware details:
  • StephenB's avatar
    Which install are you using - Australia, US, or Europe?
    Is it possible that you have the LM1200-111 model?  Those installs are only for the LM1200-100.
  • US (I'm in Canada so assuming this is correct). I was looking for the full part number and couldn't find anything beyond LM1200, even when going to 192.168.5.1/model.json.
    • StephenB's avatar
      This post has the same firmware details of yours, and that poster says they have the LM1200-111NAS
      No idea if there is an update for your version.
