collier's avatar
collier
firmware update for ac782s
Why has firware update support for ac782s?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello collier
    What issues are you having with the ac782
    DarrenM
    • collier's avatar
      collier
      Sorry, been out of contact.  The ac782s used to check for updates and did so the last time I checked in Feb 2017 but since just reports 'update error - there was a problem updating your device - try again later'.  A Telstra tech spent almost an hour trying to determine waht the problem was but could not.  I assume the embedded URL in the device is no longer operable.  Thanks
