Sykodachef
Mar 29, 2016Follower
Foxtel hub VEGN2610-1FXAUS
I'm trying to specify my wired connection to use my 5.0GHz connection instead of using 2.4 GHz connection. The only way I can seem to do it is by setting it up as wifi connection instead of a wired connection.
Help me please
Kind regards
Adam
Help me please
Kind regards
Adam
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello sykodachefI am not sure what you are trying to do if you are on a wired connection it should not have anything to do with the wireless.
DarrenM
