Ram1986
Apr 23, 2019Aspirant
frimware update problem
please help me I cant update my frimware always searching for update but can't find anything ,I tried moblie app but the same, I download the update manually but invane! what it that problem?
- W1lliamVirtuoso
What is your M1 model? You can get it from the bottom side of the label at bottom-left after back cover removed.
William
- Ram1986AspirantMr1100 telstra
- W1lliamVirtuoso
You can always download the firmware for Telstra model from here https://www.netgear.com/support/product/MR1100telstra.aspx
When I was on old firmware, can't remember which revision, it does not support manual upgrade, so you would need to try many times, on different days, to upgrade from the system.
William
