Taffeys
Feb 08, 2017Aspirant
Help! Can't remove battery cover from my AC791L Hotspot
I can get the first side of the battery cover up but I cannot remove it. Looks like the clips on the other side will not release. Any hints?
DarrenM
Feb 09, 2017Sr. NETGEAR Moderator
Hello taffeys
Page 12 shows how
http://www.downloads.netgear.com/files/aircard/AC791L/AC791L_Verizon_UG_31Aug2015.pdf
DarrenM
Taffeys
Feb 10, 2017Aspirant
Thanks but I already saw that. It is not any help. I can lift the two corners as shown but then I cannot get the clips on the opposite side to release the cover.
Tell me how to do that, please.
