agdodge4x4
Nov 18, 2017Luminary
Hook up MR1100 to Wifi Router
 I had an old Unite Pro that had to be hooked up through USB to a Cradlepoint which was then connected to my main rifi router.  This new router has a lan port.  When I plug it straight into my wifi ro...
chindrella007
Nov 05, 2019Aspirant
You can go to the setting and change the both IP address and ones reset the router facebook.if not working then you go to the other wifi adapter that is better option. you can go to the page and find more about the wifi mini adapter.
