Otteren
Feb 21, 2023Follower
How do I do a factory reset om MR 1100?
how do I do a factory reset om MR 1100?
Feb 21, 2023Guru - Experienced User
You can either do it through the settings Or you can take the battery cover off it and push the reset button under the battery for 15 seconds while powered on. Here's the att guide for it
Netgear Nighthawk LTE Mobile Hotspot Router (MR1100) - Reset Device - AT&T (att.com)
