NiklasK
Sep 24, 2018Aspirant
How to access Nighhawk M1 When in Ip Passthrough Mode (modem only)
Hi i just got the Nighthawk M1 for by buissnes as we cannot get a proper Fiber connection and DSL is WAY to slow here 0.3mb upload (sigh...)
After getting it, I setitup in Ip Passthrough Mode and disabled the Wifi and DHCP. The M1 refuses to let me give it another IP address then 192.168.1.1. It works with our ASUS AC3200 router fine but now i cannot acess the GUI on the Nighthawk M1.
How can i access the GUI after IP Passthrough has been enabled?
- JSchnee21Virtuoso
What is the IP address of your ASUS? Be sure the MR1100 is set to an IP which doesn't conflict with any other devices on your network. Also be sure it is in the same class C subnet as your ASUS hosted network.
You shouldn't have an issue changing the IP of the MR1100 I'ved mine several times. Mine defaults to 192.168.0.1. You might have to temporarily turn DHCP back on first, change the IP of the MR1100 and the corresponding DHCP ranges. Save the changes, reboot, and then turn off DHCP.
I've found that the App / attwifimanager is very dumb and won't find the management page if you change the MR1100 from the default IP. You'll need to use your browser (e.g. Chrome) and go to the IP of the mr1100. Check to make sure you can ping it first.
-Jonathan
- NiklasKAspirant
Hi, Thanks you for replying and trying to help.
I have not used the app as i set everything up from my laptop via my webbrowser.
The default gateway ip of the Nighthawk is 192.168.1.1 which is the same as my Asus AC3200, My aus triggered that it was the same IP and automaticaly wanted to reboot and change its ip to 192.168.2.1 which i allowed and whilst it is working now with the IP for the asus router being 192.168.2.1 and the Nighthawk being 192.168.1.1 I want to change the Nighthawk to 192.168.5.1 or any other Ip as i want my Asus to be 192.168.1.1 due to alot of other devices with Pre confiugured Ips. However the Nighthawk refuses to let me change its IP.
- W1lliamVirtuoso
M1 will be assigning dynamic IP to your router WAN port if IP passthrough is enabled. You can always check onthe router's WAN status, the IP assigned to the router. M1 will be stayed on the first IP address where router's WAN IP network. For example, if your router's WAN IP is on 10.188.87.100 then your M1 should be on 10.188.87.1, you can access to M1 on that specific IP address even if your PC stayed behind the router.
