incredibill's avatar
incredibill
Follower
Sep 28, 2015
How to configure Aircard 340u for port forwarding?
I can't find any means to access the advanced setup features on the device.
Any guidance is greatly appreciated.
Fred
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Incredibill
    Try log in into the Aircard by typing 192.168.1.1 or 192.168.0.1 into the web browser then it should ask you to login in defaults are usually Username:admin Password:Password. If this dosnt work you may want to find the default gateway of the device and then type that into the web browser. Then you should be able to go to settings then router then port forwarding. You may want to contact ATT for more support.
    DarrenM
