Andy2010
Apr 20, 2017Aspirant
How to configure Nighthawk M1 as 4G Modem only
Hi, I need some help please in configuring the Nighthawk to be a 4G Modem only (no router or wireless). Current Set Up: - Billion BiPAC 700 4G/ADSL Router + All current equipment is co...
dam_ged
Feb 15, 2018Guide
Looking at the M1 + a classic router (e.g. R7000) in replacement of R7100LG.
Is the Passthrough mode available now?
JasonN
Feb 15, 2018NETGEAR Employee Retired
Hi dam_ged,
Yes, the M1 does support IP Passthrough mode.
Please use the link below as reference, :]
- Jason N
- UK-basedFeb 16, 2018Luminary
JasonN- your link leads to this answer, which contains an incorrectly formed URL, comprising 2 contiguous URLs. Was your link intended to redirect to this URL, which is the second half of the bad URL?
- JasonNFeb 16, 2018NETGEAR Employee Retired
Hi UK-based,
That is weird. Yes, I was going for the first link but both links will work also. :]
It was just to confirm that the feature was available after that firmware version.
Thanks for clearing that up!
- Jason N
