wmlooi
Jul 20, 2016Aspirant
How to connect HyperTerminal or Putty with Netgear AC785?
Hi, I'm trying to connect AC785 with HyperTeminal or Putty but no luck to make it works. I want to do some AT commands test? Please help. Thanks.
DarrenM
Jul 21, 2016Sr. NETGEAR Moderator
Hello Wmlooi
What exactly are you trying to test for?
DarrenM
wmlooi
Jul 27, 2016Aspirant
Hi DarrenM,
The Netgear AC785 is a good product and I'm happy to bought it. But, it lacks of some features such as compose/send SMS and USSD code. That's why I want to connect AC785 with HyperTeminal or Putty to test some AT commands to see whether the modem can compose/send SMS and USSD code.
Hi Wstyle1,
The Netgear AC785 can connect with my Android phone using Netgear AirCard app. This app has a lot of features and one of them is read SMS. Yes, only can read but cannot compose/send SMS. No USSD feature.
- wmlooiSep 04, 2016Aspirant
OK, I managed to make it work with HyperTerminal. I just use it to send a few USSD codes.
The new firmware I just updated now can compose/send SMS. This is good.
It will be better if the next update can add the USSD code feature.
Thanks.
Oh, fyi. I need to install the below driver in order to make it work.
Thanks.
http://www.downloads.netgear.com/files/aircard/AC_785S_Telstra/AC78xSDrivers.exe
