wmlooi
Jul 20, 2016Aspirant
How to connect HyperTerminal or Putty with Netgear AC785?
Hi, I'm trying to connect AC785 with HyperTeminal or Putty but no luck to make it works. I want to do some AT commands test? Please help. Thanks.
wmlooi
Jul 27, 2016Aspirant
Hi DarrenM,
The Netgear AC785 is a good product and I'm happy to bought it. But, it lacks of some features such as compose/send SMS and USSD code. That's why I want to connect AC785 with HyperTeminal or Putty to test some AT commands to see whether the modem can compose/send SMS and USSD code.
Hi Wstyle1,
The Netgear AC785 can connect with my Android phone using Netgear AirCard app. This app has a lot of features and one of them is read SMS. Yes, only can read but cannot compose/send SMS. No USSD feature.
wmlooi
Sep 04, 2016Aspirant
OK, I managed to make it work with HyperTerminal. I just use it to send a few USSD codes.
The new firmware I just updated now can compose/send SMS. This is good.
It will be better if the next update can add the USSD code feature.
Thanks.
- wmlooiSep 04, 2016Aspirant
Oh, fyi. I need to install the below driver in order to make it work.
Thanks.
http://www.downloads.netgear.com/files/aircard/AC_785S_Telstra/AC78xSDrivers.exe
