wmlooi
Jul 20, 2016Aspirant
How to connect HyperTerminal or Putty with Netgear AC785?
Hi, I'm trying to connect AC785 with HyperTeminal or Putty but no luck to make it works. I want to do some AT commands test? Please help. Thanks.
wmlooi
Sep 04, 2016Aspirant
OK, I managed to make it work with HyperTerminal. I just use it to send a few USSD codes.
The new firmware I just updated now can compose/send SMS. This is good.
It will be better if the next update can add the USSD code feature.
Thanks.
wmlooi
Oh, fyi. I need to install the below driver in order to make it work.
Thanks.
http://www.downloads.netgear.com/files/aircard/AC_785S_Telstra/AC78xSDrivers.exe
