Elmer2flp
Jul 01, 2017Aspirant
How to create ports in firewall using LB1120 Modem?
I am having a really hard time creating firewall ports so I can access connected devices. I have the LB1120 connecting to the internet, then an ethernet cable connecting the LB1120 to the WAN jack on...
Elmer2flp
Jul 04, 2017Aspirant
No. But in desperation, I plugged the Ethernet cable from the LB1120 into one of the LAN jacks on my router INSTEAD of the WAN jack, and now all the devices can see each other and have outgoing access to the internet, so it appears the router is acting like a simple network switch. HOWEVER, I still can not get my LAN to accept incoming traffic, even though I create firewall ports in the LB1120 and in the router. HELP! Again, the only incoming traffic permitted seems to be from Splashtop.
Elmer2flp
Jul 08, 2017Aspirant
Well, I've tried several times to create ports in the LB1120 firewall, but when I test them on a port testing website, no luck. I think in retrospect my mistake was connecting a router to the LB1120 when I should have connected a simple network switch. I believe somehow the router is interfering with the ports I try to create in the LB1120 firewall, even though I create the same ports in the router as well. I should also add that only the LB1120 is in DHCP mode, not the router.
